0 members (),
191
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | I know its possible with modifications. I remember seeing a picture of it somewhere (on here I believe but I couldn't find it).
Anyways, I know the frames are different, but here was my thought. Switching out all the cross sills to the 54' spec. then just using the 47-53 bedsides, front panel and tailgate. The truck came with a "year correct" bed to replace the 73-87 bed which was on it... being a newb to the classic truck world... I missed this when I purchased the truck. The PO said it was a 54 bed... which it wasn't... it was the earlier version. Everything is in fairly decent shape metal-wise.... so I'd like to use it (as I'm on a very tight budget like most people).
Any tips/help would be appreciated! Thanks fellas! | | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I think the frame is different in the amount of arch over the rear axle. So I would think it would be mostly a matter of mounting to the bed, it would need different blocking under it to make it sit level. I was thinking that from 1954-87 the bed box stayed the same, only the rear fenders changed.
John | | |
