1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#966888 08/25/2013 7:56 PM
This stamping is on the housing of a '46 ignition switch. Is the "6301" a key code? [IMG]http://i1302.photobucket.com/albums/ag140/68ironhead/igswitch001_zpsa33be435.jpg[/IMG]
It is doubtful the key code would be stamped on the housing. I have seen some key cylinders stamped with the code but most are not. Most door lock cylinders are stamped with their code.
OK, should have checked the parts manual first,
that stamping matches the factory part number only, not key code.
anybody know where you can get one of them, mine is not in good shape. Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
homer, you won't find repro 41-46 switches, but Chevs of the 40s has some posibilities that could be adapted, and you can always try a parts wanted post
american classic truck parts had the switch for my 46 1/2ton, they have almost all the truck parts for you're truck
