0 members (),
146
Mod | | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 45 | Hi, Need to lower my 54 Chevy 3100 about 1.5 inches in the front and maybe 1 inch in the rear. I know the rear I can remove a couple leafs. What can I do up front? Still running the 16 inch wheels with Coker's 6.00 x 16. It will not fit in my trailer.
awk | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Can you not remove leafs on the front as well? Or you could just drive it  | | | | | Joined: Sep 2011 Posts: 305 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 305 | I want to lower mine too and was told you could remove some fronts.
| | | | | Joined: Jul 2013 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 45 | So you think I can remove a couple leafs from the front too. Like to know how much will that lower it? It would be nice to here from someone that has done this. I'll look at more tonight. Thanks, awk | | | | | Joined: Nov 2011 Posts: 22 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2011 Posts: 22 | I put new springs under my front end that were made to lower a truck. I lowered the front 2" and used a lowering block in the rear. Scares me to remove leafs.the springs were fronm Detriot springs | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | How many leafs do you have in the front now, I believe they originally have 7? I've removed the two short lower leafs and it will lower at least 1 1/2". While your at it, you can add the plastic spring liners, I understand this will soften the spring ride, and the springs will give a little more? Remember to put the removed leafs on top so you won't have to replace the U-bolts. | | | | | Joined: Sep 2011 Posts: 305 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 305 | Good point about the u bolts, never thought of that.
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | I removed my 2 shortest front leafs and got a result similar to yakimabowtie at about 1 1/2" and found the ride a bit smoother. IIRC I used some drill bushings (like thick washers) with the stock U bolts and was a bit surprised that the steering wheel position was different by 90 degrees after removing them.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Sep 2011 Posts: 305 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 305 | Nice truck Curt. So it turned your steering wheel half a turn? Did you use the plastic spring liners too? Wonder what taking three out would do? Thanks for your input. John | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Thanks. IIRC removing 3 meant needing to source alternate U bolts but I could be wrong. I didn't disassemble and add plastic as mine have some wear and will be replaced rather than reconditioned giving me an excuse to try and wear them further.  The steering wheel moved 90 degrees AKA 1/4 turn requiring repositioning but at that time I had recently had it off and was no big deal to square it up.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Sep 2011 Posts: 305 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 305 | Oops, 90 degrees = 1/4 turn. does it effect the steering? That kinda worries me. I was thinking of taking three out. Well I can always put it back, I had a guy tell me to use a zippy blade and cut them off. Ill put them to the top so the u bolt will work. | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | unbolt the center bolt and take leaves from the bottom and put them on the top of the spring and put the center bolt back in, I took four leave from the bottom of mine and put them on the top and lowered my truck 2 1/2 in. and could still use the u bolts... easy to do
