10 members (55shaker, Wally / Montana, Gdads51, Nick in Manitou, Otto Skorzeny, BillCollins, MickeyP, sron48, KCMongo, 1 invisible),
104
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,704 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2013 Posts: 41 | Hello everyone I am a new user on here and proud owner of a recently purchased running 57 chevy 3100. A lot of work need to be done on it, but need the lights to work in order to drive it to and back from my buddy's shop.
Headlights work, one is always on until you hit the dimmer then both turn on, is this normal?
Just hooked up the parking lights, one wire coming from the headlight harness. There were two wired on the actual new parking light. One green, one black. To my surprise the black one was the hot one an the green had to be grounded onto the inner fender. Is this correct?
Went to install the back lights (two wired), mind you they haven't been mounted onto anything yet. I hooked up one wire to whatever was left from the old wiring and the second wire I grounded to the frame. The light works, both on the first and second position on the light switch. I hit the brakes and nothing changed, turns out the white wire and red wire weren't hooked onto the brake switch located under the firewall. I hooked them up and still nothing changed, not even a flicker? Would it help to mount the light onto the frame or bed in order for it to work correctly?
One more thing, on my gauges, what does the little red light mean? It's on...
| | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Some confusion here. Green is for the head light Hi beam. Tan is the low beam. Natural/white is the brake light and black is the tail light. Check the link for "Old Online Chevy Manuals" and follow the wiring diagram. Should at least get you started.
Steve H
| | | | | Joined: Aug 2013 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2013 Posts: 41 | The parking lights I bought came with a green/teal and black wire. The taillights came with a black and white wire. | | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | I believe that red light above the speedometer indicates that the lights are "on". | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The tail and front lights ground through the light housing. The two wires on the front lights are park and turn and the two wires on the rear lights are for brake and tail. You must have the housings grounded good for them to work. You may need an extra ground strap from the bed to frame because of 50+ years of corrosion in the original mount bolts.
Both headlights should burn in both positions. You could have a burned out low beam on one side.
The red indicator is for high beams. | | | | | Joined: Aug 2013 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2013 Posts: 41 | Cletis, thank you so much. I'm gonna tinker around with it for a bit this weekend. I'll keep you guys posted! | | | | | Joined: Aug 2013 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2013 Posts: 41 | Also I don't have any turn signals on this truck. My best guess as to why there is only one wire going to the parking lights? So instead of grounding my parking lights with the green wire, should I just not connect it to anything? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | When you use the green light for ground you are sending power to both filaments of the bulb. Since you don't have turnsignals you need to terminate that wire and save it for later. Install the housing in the truck so you'll have a ground to it. Then try each wire with the light wire to determine which you need. Use the dim one and tie off the bright one. | | | | | Joined: Aug 2013 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2013 Posts: 41 | Sounds like a plan, thank you! | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | where you at in Texass... you should consider going to the welcome forum and introduce your self, we would like to know more about you..we also have a place for guys in Texas to chime in.. Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Aug 2013 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2013 Posts: 41 | So I got the parking lights figured out, only needed the black wire for the dimmer light, green wire is for when I add turn signals. Great!
Taillight is almost figured out as well. I've got it hooked up to where the dimmer bulb lights up when the light switch is pulled out on the first and second spot. When I hook up the second wire which is supposed to be the brighter stop light, it stays bright the whole time it is on. Not sure what's going on, would like to have a running and stop light. I have two wires coming from the harness to the back. I have two wires hooking up to the brake switch and tried them two different ways (switch the posts hooked up). I have a running light, but no stop light. Help! | | | | | Joined: Aug 2013 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2013 Posts: 41 | Maybe I need a new brake switch? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Do you have a multimeter? You need one to check the operation of the switch. | | | | | Joined: Aug 2013 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2013 Posts: 41 | No I don't. Maybe I could take the wires off and bypass with a bridging wire to see if the brake lights turn on and off that way. If they do, maybe I have a bad switch? | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Is the arm on the stop switch? | | | | | Joined: Aug 2013 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2013 Posts: 41 | | | | | | Joined: Aug 2013 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2013 Posts: 41 | That's what I don't understand, mos people that have problems with the brake switch say it won't activate the stop light, I'm the complete opposite. I want the brake light to turn off, unless I'm hitting the brake of course. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | As the brake pedal reaches the top rest position, you should hear a click from the brake switch as it turns off. Most of these trucks have a brake pedal that is higher than the clutch. Trying to adjust it down can cause the the brake switch to stay on. | | |
