| | | Forums66 Topics128,080 Posts1,056,314 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 12 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 12 | Hi. I don't know if there is anybody out there who has done it but I want to run an automatic transmission in my 52 GMC pickup. The catch is I want to use an automatic shifter I got out of a 54 Hydramatic GMC. My setup is a GMC 302 with a 200r4 transmission. Will this be a straight forward project or are there any complications I'll run into? I know I'll have to change the glass in the shifter because the shifting patterns are different in a modern transmission. Any advice would be helpful. Thanks | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | I've seen it done but haven't done it myself. I don't think it will be a huge project, but it will take a little bit of mock-up and fab to get the geometry right. It's no different than hooking any column shift up in a vehicle it wasn't in to start with. Just take your time and mock everything up. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Save the glass and sell it in the Swap Meet.
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | I am putting an automatic in a '48 2 ton. I was planning on making an adaption of the floor shifter from a 50's Powermatic. Haven't seen a GMC Hydramatic shifter, do you know if they are similar? | | | | | Joined: Jan 2009 Posts: 12 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 12 | I don't know, sorry. It's sounds like an interesting project though. | | |
