2 members (dt235sd, Sjm),
99
Mod | | | Forums66 Topics128,283 Posts1,058,505 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 217 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 217 | I'm starting to hear a slight knock for the engine and I think it is time to tighten the rods and bearings. Any advise on how much to tighten or what to look for once I have the oil pan off?
| | | | | Joined: Sep 2012 Posts: 217 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 217 | Isn't "slight knock" like "being a little bit pregnant" or have I missed something? LOL---
You are probably looking at a rebuild. Pull the pan and rod caps first and check their condition then pull the mains. No such thing as tighten them up. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | A little more diagnostics would be in order. You can start by pulling one plug wire at a time, that will usually cancel out a rod knock. | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Which engine?? Babbit rod bearings, the only way to tighten them up would be to file the bearing caps. Not the best idea though. Probably like vette said, need to pull the pan and check clearances and condition of rod and main bearings. Get you some plastigage and check clearances... John
| | | | | Joined: Feb 2004 Posts: 29,951 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,951 | Guys, don't offer advice about things you don't understand. Adjusting rod and main bearing clearance by changing the shim pack was something we did frequently on the Babbit-rod engines back in the 1950's and 60's. I sent him a PM about how to do it. Jerry
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Tighten your sphincter, because it's probably going to need a rebuild. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | A little more research and a little less smart [censored] goes a long way in this hobby ....... | | | | | Joined: Feb 2004 Posts: 29,951 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,951 | Isn't "slight knock" like "being a little bit pregnant" Yes, Don, I agree with you! Jerry
| | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | i had a slight knock at idle when hot, when my 228 was in my 40. it didnt cost me a thing to fix it. i increased the idle speed about 50 rpm and the knock went away. so depending when the knock apears or is noticable may be all it will take. if not what ever hot rod told you will be the correct way and most cost effective  | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Sorry, I didn't think they used shims on the babbit rods.... Knew they had shims on the insert rod bearings, figured the babbit rods were machined to size after they were poured. | | | | | Joined: Mar 2010 Posts: 10,336 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,336 | Every time someone besmirches the Babbitt bearing engines I just smile, drop the oil pan, remove a shim or two and keep on driving. Whereas the guy with insert bearings with a rod knock is screwed.
| | | | | Joined: Jul 2013 Posts: 200 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 200 | Sorry, I didn't think they used shims on the babbit rods.... Knew they had shims on the insert rod bearings, figured the babbit rods were machined to size after they were poured. The babbit is a lot softer than an insert bearing and the clearance goes away quicker, so it is a serviceable fix that most all babbit engines were designed to remedy back in the day. Model A's and T's also were common to shim to adjust clearances.
We cannot solve our problems today using the same thinking we used when we created them! Albert Einstein
| | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | Insert bearings are lined with babbit. Its just they are not poured/scraped... but applied with much more precision. So we all still have 'babbit pounders' if you think about it  Chevvy/GMC/Ford trucks had insert bearings in the early 40's. My 42 Ford and 43 GMC had them as original equipment. Not sure why Chevvy took so long to get them out of the civvy engines. And one man's 'knock' is another man's 'tap'. Rattles seem to be universal. | | | | | Joined: Mar 2010 Posts: 10,336 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,336 | Times were different back then. Labor was cheap and parts were expensive. I'm guessing they stayed with the serviceable bearing rather than the replaceable bearing for financial reasons.
| | | | | Joined: Feb 2011 Posts: 1,363 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,363 | There used to be shims for the standard insert type bearings. I would not recommend removing material from the caps, unless you are doing resizing the bores.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
