5 members (diseasel, Bill Hanlon, 59 fleet, Phak1, Wayne67vert), 109 guests, and 1 robot.
Topics128,035
Posts1,055,566
Well, my Bendix TU-FLO 300 Air Brake Compressor is pretty much shot. Bendix was kind enough to give me the number to the people they use to rebuild their compressors, but their price is astronomical. $522.00 plus tax to be exact. So I bought an International Harvester compressor off of eBay that I thought looked similar. Turns out it's a bit larger and has more port holes than the TU-FLO. Where the TU-FLO has four port holes this one has five. Does anyone know if I will be able to use this compressor and which port holes to use?
Glory Bound...
$522 isn't 'astronomical', particularly if you buy a few incorrect items instead wink .... "port holes" doesn't tell the story, there may be inlet and outlet for water cooling [each side of the head], lube inlet and outlet [in the 'crankcase'], and one place for air outlet, with a smaller nearby aux port for the unloader function ... you need to identify what the ebay compressor actually is, rather than just what it's from, you might find it's made by Bendix, the most common ... you might be able to ID it using the pics in this catalog
It has an International Harvester part number of 276468-C93. It does come up the Bendix catalog, but I was not able to get the info I needed off of that.
Glory Bound...
if you have the IH number, then you want to talk to an IH dealer wink
Bendix compressors are all pretty much the same. Only more cfm like 400, 501, 550, etc. If your pulley will fit it, you can make it work. They all have a bunch of extra port holes that you plug with 1/8" pipe plugs. The number is probably an old IH number that is meaningless, but as long as it is a belt driven compressor, you can make it work.
