0 members (),
79
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 127 Shop Shark | | Shop Shark Joined: Mar 2008 Posts: 127 | Well, my Bendix TU-FLO 300 Air Brake Compressor is pretty much shot. Bendix was kind enough to give me the number to the people they use to rebuild their compressors, but their price is astronomical. $522.00 plus tax to be exact. So I bought an International Harvester compressor off of eBay that I thought looked similar. Turns out it's a bit larger and has more port holes than the TU-FLO. Where the TU-FLO has four port holes this one has five. Does anyone know if I will be able to use this compressor and which port holes to use?
Glory Bound...
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | $522 isn't 'astronomical', particularly if you buy a few incorrect items instead  .... "port holes" doesn't tell the story, there may be inlet and outlet for water cooling [each side of the head], lube inlet and outlet [in the 'crankcase'], and one place for air outlet, with a smaller nearby aux port for the unloader function ... you need to identify what the ebay compressor actually is, rather than just what it's from, you might find it's made by Bendix, the most common ... you might be able to ID it using the pics in this catalogBill | | | | | Joined: Mar 2008 Posts: 127 Shop Shark | | Shop Shark Joined: Mar 2008 Posts: 127 | It has an International Harvester part number of 276468-C93. It does come up the Bendix catalog, but I was not able to get the info I needed off of that.
Glory Bound...
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if you have the IH number, then you want to talk to an IH dealer  Bill | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Bendix compressors are all pretty much the same. Only more cfm like 400, 501, 550, etc. If your pulley will fit it, you can make it work. They all have a bunch of extra port holes that you plug with 1/8" pipe plugs. The number is probably an old IH number that is meaningless, but as long as it is a belt driven compressor, you can make it work. | | |
