1 members (Hotrod Lincoln), 49 guests, and 6 robots.
Topics128,021
Posts1,055,355
Members48,420
#966233 08/23/2013 1:36 AM
can anyone identify this engine for me..235 or 216?
Casting # next to distributor X377506
Above fuel pump
GM 48
3835327
Thanks Dan
DJRoy #966247 08/23/2013 6:45 AM
Dan,
There a some Canadian GM casting codes at the bottom of this post. Maybe someone will post a better source of Canadian codes - I do not recall anyone making/posting a list?
You can determine if your truck is a high oil-pressure 235/261 or a low-pressure 216/235 by a few characteristics.
low pressure:
- 15 head bolts
- valve cover attaches to head with two bolts
- the is a small triangular sheet metal plate on the block in the middle of the manifold side of the block
- water pump body extends above the top of the block
high pressure:
- 18 head bolts
- valve cover attaches to head with 4 machine screws
- water pump body is completely below the head
You can usually determine the year of the engine from date casting codes.
high pressure:
- 18 head bolts
1953 Power Glide engine is an exception to this.
It is high/full pressure and has the two bolt valve cover, in the USA anyways.
My Blog
DJRoy #966368 08/23/2013 5:21 PM
Another correction:
Water pump above the head in 54/55 on high pressure engines (with 4-screw valve covers).
