7 members (Gdads51, Otto Skorzeny, Wally / Montana, LuckyLee, MickeyP, TUTS 59, kades51),
72
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,051 Posts1,055,710 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 16 New Guy | | New Guy Joined: Dec 2008 Posts: 16 | After many years disassembled I am finally getting my truck back together. I started to reassmble my rechromed headlights and I think there was a copper grounding strip for the relecter to the bucket. There is a small hole that could be for a rivet. I think the shop removed it when they did the chromeing. Do I need it? Thanks in advance , Mike. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | So I would think that you bulb has two contacts on the base, correct? The third connection is ground through the body of the bulb. That has to be connected to the body ground or sheet metal somehow. | | | | | Joined: Dec 2008 Posts: 16 New Guy | | New Guy Joined: Dec 2008 Posts: 16 | I went back out to the shop and found that the reflecter makes contact in the bottom of the fit of the bucket that it fits into. So I imagine it makes contact through the sheet metal this way. Thanks , Mike. | | |
