| | | Forums66 Topics128,047 Posts1,055,621 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 82 | Does anyone have a picture of where the oil pressure gage sensing line connects to a 216 engine. It is on my recent 1941 Chevy pickup | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | With an oil filter or with out? With a filter, there should be a "T" oil line on one end and oil pressure line on the other. No filter? should be an elbow. Oil pressure line goes on that. Driver side towards the back of the block down by the oil pan seam. I think..:)
Steve H
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The outlet with the 1/4 in pipe plug in the lower corner of the block on the left side is coolant drain. The oil outlet is about 2/3 way back & about 3/4 way down. It has a 1/8 in outlet. If there is a plug in it you can remove it & install an appropriate fitting for your tube. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | On page 5 of my photo bucket I have a good photo about 1/2 way down. | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Yeah! GWWirth has the location. I was just lazy I guess. My bad.
Steve H
| | | | | Joined: Apr 2013 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 82 | Thanks for the info. Do i have to use the plug closest to the radiator or can i use the one by the firewall. I do not have an oil filter. Nice truck. Where are you located. I am in Jacksonville, FL. | | |
