4 members (lumbersawyer, Hush, 2 invisible), 64 guests, and 3 robots.
Topics128,026
Posts1,055,407
Members48,422
#965731 08/21/2013 3:01 PM
Does anyone have a picture of where the oil pressure gage sensing line connects to a 216 engine. It is on my recent 1941 Chevy pickup
With an oil filter or with out? With a filter, there should be a "T" oil line on one end and oil pressure line on the other. No filter? should be an elbow. Oil pressure line goes on that. Driver side towards the back of the block down by the oil pan seam. I think..:)
Steve H
eyell #965863 08/21/2013 10:14 PM
Riding in the Passing Lane
The outlet with the 1/4 in pipe plug in the lower corner of the block on the left side is coolant drain. The oil outlet is about 2/3 way back & about 3/4 way down. It has a 1/8 in outlet. If there is a plug in it you can remove it & install an appropriate fitting for your tube.
1972 Chevy c10 Cheyenne Super
eyell #965865 08/21/2013 10:16 PM
On page 5 of my photo bucket I have a good photo about 1/2 way down.
Yeah! GWWirth has the location. I was just lazy I guess. My bad.
Steve H
Thanks for the info. Do i have to use the plug closest to the radiator or can i use the one by the firewall. I do not have an oil filter. Nice truck. Where are you located. I am in Jacksonville, FL.
