8 members (2-Ton, DadsFirstPickup, 32Fordpuchoptop, FAST55, Otto Skorzeny, mason86, rfs56trk, TexasJim50), 73 guests, and 2 robots.
Topics128,049
Posts1,055,661
#965803 08/21/2013 6:50 PM
I purchased a new battery ground strap and a engine ground stap from Jim Carter when I got the battery ground.
Where is the proper location for the engine ground strap on the engine and do I really need it ?
Thanks in advance , Mike.
excess grounds do no harm and might mean a problem that won't happen wink where does the ground terminal of your battery attach? the battery connected directly to the engine is best for the starter circuit, like to the bell housing or a starter bolt - if your battery grounds to the frame, then put the 2nd strap from the frame to a starter or bellhousing bolt, good idea to have a 3rd ground from the frame to the cab to insure lights and accessories get proper grounds
Hello Bill,My battery grounds to a bolt on the back of the transmision. I will likely connect the other ground to the cab.
Thanks , Mike.
You should have a minimum of 3 main grounds. Engine to frame, battery to engine, and body to frame.
My 46 GMC on Photobucket
Also don't forget to use star washers to bite into metal for a good connection. Pat
1966 Chevy C 30 1 ton truck
