| | | Forums66 Topics128,050 Posts1,055,646 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 16 New Guy | | New Guy Joined: Dec 2008 Posts: 16 | I purchased a new battery ground strap and a engine ground stap from Jim Carter when I got the battery ground. Where is the proper location for the engine ground strap on the engine and do I really need it ? Thanks in advance , Mike. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | excess grounds do no harm and might mean a problem that won't happen  where does the ground terminal of your battery attach? the battery connected directly to the engine is best for the starter circuit, like to the bell housing or a starter bolt - if your battery grounds to the frame, then put the 2nd strap from the frame to a starter or bellhousing bolt, good idea to have a 3rd ground from the frame to the cab to insure lights and accessories get proper grounds Bill | | | | | Joined: Dec 2008 Posts: 16 New Guy | | New Guy Joined: Dec 2008 Posts: 16 | Hello Bill,My battery grounds to a bolt on the back of the transmision. I will likely connect the other ground to the cab. Thanks , Mike. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | You should have a minimum of 3 main grounds. Engine to frame, battery to engine, and body to frame. | | | | | Joined: Feb 2013 Posts: 56 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 56 | Also don't forget to use star washers to bite into metal for a good connection. Pat
1966 Chevy C 30 1 ton truck
