7 members (FAST55, TUTS 59, Wally / Montana, Wickedbass, Mike Burns, Gdads51, Donf),
85
Mod | | | Forums66 Topics128,065 Posts1,055,870 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | Somewhere online I've seen large radiator water filters for sale. Thought at the time they were stupid. Now that I'm trying to revive the old 216 that hasn't run in 50 years I'm worried about rust throughout the engine and then it coursing through the new aluminum radiator I'm about to install and now the filter idea sounds great. Anybody running one of these and do you recommend it? Can you buy them at your FLAPS?
Thanks.
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | seems like a waste of money Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | get some flushing solution, soak and flush the block well before you put in the new rad, refill with soft water and keep the right antifreeze in it .... and use the truck, don't let it just sit the next 50 years
Bill | | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | Excellent advice Red58 and whom ever will Listen!
| | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | | | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | Good advice. Thank you. Still curious about a filter though?!?
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | there appear to be a few different breeds of filters around .... for the good that they [wouldn't] do, some folks do use them, better to make sure your temp gauge is functional and tend to your cooling system if the gauge starts deviating from it's usual behavior
once you've cleaned out the block well, and if you use low-mineral content water with good antifreeze, there won't be much of anything in there to filter, just stay on top of preventive maintenance per your shop manual
Bill | | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | The idea was to filter out any sediment that's going to be stirred up once I get this old engine running after being dormant 50 years. I'll flush it out as others have recommended, but realize that I can't get everything out before I start it. The filter idea came to me as a way to catch particles that let loose once it's running and becomes hot.
Thanks.
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | in theory that sounds like a good idea. in reality you decide. i wouldnt want to restrict a system that is somewhat already restricted. i wouldnt be to concerned with what is suspended and going through the system since you can flush that out regularly. its the stuff thats now part of the block and head. id start by removing the pet cock and go from there. refill with soft water as red said or us deionized water. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | You are correct about the garbage getting into the new radiator. You DO NOT want that. So flush it with a hose till runs clean as advised above, without radiator. Shoot water into the inlet for awhile, then shoot water into the outlet (backflush) for awhile. You can mix and match any radiator hose that helps you get the garden hose gun into it. Use a rag as a seal to keep leakage to a minimum. I don't know anything about a 216, but I second what Ashton says, if it has petcocks on the block, take them out while flushing. You can't get gunk to run thru a little opening in a petcock. Then run engine with bottom radiator hose hooked up to radiator, but not top hose. Arrange top hose (attached to engine outlet) so that it runs into a catchment to watch water color. Take out thermostat and watch the heat gauge. It must get up to operating temp. Keep filling radiator with a hose. Hopefully top hose will start flowing more gunk out into a bucket. Block radiator air flow with newspaper or remove fan. I do not know if this works. Either I just thought of it or I have done it. It's kind of similar to how you use one of those flushing kits. If you could keep filling radiator with hot water, that would be even better.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | Thanks everyone for the good advice! Sounds like a long and thorough flushing is what is needed most and I will be doing that this weekend. Will look online for a filter but I'm not going to worry about it anymore.
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Those filters are just a tube with some screen in it. They would plug up all the time, which is good and bad. They are $60 at Summit.
