2 members (Hush, Forty9),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 253 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 253 | Are there solid core copper plug wires available for stovebolt sixes and who has them? I don't mind making up my own set if they are available that way.
-Mike-
1945 Chevrolet G 506 1.5 Ton Military 4X4 1967 Jeep Cj5 with 283 SBC
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | check your FLAPS, NAPA has DIY wire sets
Bill | | | | | Joined: Dec 2010 Posts: 253 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 253 | My NAPA guy says "can't get'em!" Anybody have a NAPA part #? No Flaps in these parts.
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | FLAPS is Favorite Local Auto Parts Store. Napa should have the old style wires. May have to ask for some for an older six cylinder tractor.
Parts Plus stores should have metal core plug wires, and I'll see about the part number in the morning. I'm not sure about the copper part though. Jeggs and Summitt Racing would be a good place to look.
Unless you're wanting to be a purist, the new plug wires work fine on these old stovebolts. Less radio noise too if you're lucky enough to have one. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Dec 2010 Posts: 253 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 253 | Thanks all!
No I'm not trying to be a purist, so maybe I should back this up a little and ask will copper wire and non resistor plugs give the best and hottest spark with these old points ignition systems? That's all I'm really after, otherwise I'll use the carbon wires from NAPA and their resistor plugs. I don't need Hi Performance, just good performance.
FLAPS! LOL. I've seen that used here for quite awhile and thought that it must be a west coast chain of auto parts stores. That makes me look NSB (not so bright). :>)
Roy, I'm still loving your old 261! It's been a great motor for my truck.
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Glad to hear it. That was a good engine.
The modern wires should give you better spark than the older metallic wires, and with less static for anyone around with a radio. And they will work fine with non-resistor spark plugs. | | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | i got mine at tractor supply, and they are copper core. it was a universal spark plug set that even looks original for $20. Indy
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | |
