0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#96546 08/03/2006 10:40 PM | Joined: Jul 2005 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 57 | Silly maybe but I need a new generator is there a difference in what year I use I am running a 12 volt system. Thanx, Jack
Try prayer as the first response rather than a last resort ...
#96547 08/03/2006 11:53 PM | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | | | |
#96548 08/04/2006 4:09 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | osidejack,
Unless you are keeping your rig stock, remember that an alternator is a option. Not to difficult to do the swap either.
If the cost/availability of a new generator is a issue, a auto electric shop could probably rebuild your existing unit quite reasonably.
Has someone tested your rig to verify that the generator is at fault...there are other components in the system that could cause a no charge condition! It's hard on the bank account to just replace items until the problem disappears.
Stuart | | |
#96549 08/04/2006 6:17 AM | Joined: Jul 2005 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 57 | Stuart , Had the generator tested today and it is out. There is one shop in my city that does the rebuild but he's leaving on vacation for 10 days. Hoping to remedie this b4 then. Altenator conversion is okay but the gain/ lose is what I question. Seems to me both sides have valid points. Thanx for your imput I'm still on the hunt. Not really in a rush so--- Jack
