1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
#965206 08/19/2013 10:47 PM
I was curious how easy it is to swap a 4-spd transmission from a 1963 chevy c60 into a 1959 chevy viking c60? they both have straight 6's. Is it just bolt up or a different bellhousing?
hardy541 #965211 08/19/2013 11:13 PM
same trans, should be a direct swap
hardy541 #965212 08/19/2013 11:18 PM
3B Offline
Hy hardy541, if everything is stock (the way they left the factories) then they should be the same transmission (SM420), so they should be a drop in swap, hope that helps.
Thanks for the info. Guess I will drop the trannys and haul the 63's up to the jobsite and swap em lol(state forester thinks we need a running firetruck wink
