| | | Forums66 Topics128,057 Posts1,055,815 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2012 Posts: 20 New Guy | | New Guy Joined: Apr 2012 Posts: 20 | I was curious how easy it is to swap a 4-spd transmission from a 1963 chevy c60 into a 1959 chevy viking c60? they both have straight 6's. Is it just bolt up or a different bellhousing? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | same trans, should be a direct swap
Bill | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy hardy541, if everything is stock (the way they left the factories) then they should be the same transmission (SM420), so they should be a drop in swap, hope that helps. | | | | | Joined: Apr 2012 Posts: 20 New Guy | | New Guy Joined: Apr 2012 Posts: 20 | Thanks for the info. Guess I will drop the trannys and haul the 63's up to the jobsite and swap em lol(state forester thinks we need a running firetruck  | | |
