0 members (), 76 guests, and 3 robots.
Topics128,081
Posts1,056,318
Members48,442
My truck has Air over Hydraulic Brakes and the cab marker light switch (mounted on the steering column) must be pulled out in order to get the brake light to work. Does anyone know if these switches are still available? If so, where?
Glory Bound...
3B Offline
Hy rautru, it seems to me you have some interesting wiring in your truck, the cab marker light switch should have nothing to do with the brake light switch power or output. I have never actually seen a switch mounted to the steering column, all of the marker lights I've come across have been wired into the vehicle light switch.
Hey Spanky,
Look at this video. At 2 minutes 27 seconds the guy is talking about the 4-way flasher switch. My switch is pretty much the same, but it does not light up. The guy that sold me the truck said it was in case there was an air leak so that the brake light would not drain the battery. [url=http://www.youtube.com/watch?v=Fz4OsShME7E][/url]
Glory Bound...
sounds very much something added on by the PO after he had a problem that resulted in draining the battery grin your only alternative [beside rewiring the truck as original] is to take that switch to a good parts store and see if they can match it
Thanks, I shall try that tomorrow.
Glory Bound...
i can't find the video rautu. I agree with the other guys on that switch you speak of. All marker/clearance lights I've seen on medium duty trucks have been wired into the headlight switch. Got a picture of the switch you speak of? I've seen an accessory 4 way flasher switch that lights up, when activated, but not a marker/clearance light switch.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Hindsight is 20/20 and looking back I should have taken a picture. I will tomorrow.
Glory Bound...
