6 members (GRNHydra, 49nut, Wally / Montana, cmayna, Hotrod Lincoln, 1 invisible), 184 guests, and 1 robot.
Topics128,087
Posts1,055,980
Members48,430
#964324 08/16/2013 10:00 PM
V
V Offline
Got the eng mounted but I think I see a problem. I was going to use the original brake linkage ut with the exhaust it doesn't look like the linkage in the floor will work. Anyone been down this road? I didn't plan on firewall mount for master cylinder.????? Thanks for any advice. '51 3100 LS1 5.3 w/4l60E trans---
fire wall or tucked in the frame would be my method
V
V Offline
Had planned to go original mount in the frame but it looks like that will be a real challenge. If someone makes a header that dumps far enough in frt of the firewall it would go maybe. I just hoped someone else had been there--done that--???
Check with No Limit Engineering.
www.nolimitparts.com
I believe I saw a mount setup at their shop that moves the booster and MC back behind the trans in order to increase clearance.
regards,
Leon
V
V Offline
I sent them a e-mail asking if they had anything.
