| | | Forums66 Topics128,036 Posts1,055,452 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 75 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 75 | Whats the best way to clean a speedo cable? can I pull the cable out? what do I lube it up with?
Thanks David | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes you can pull the inner out, clean it well with solvent and flush the outer sheath thoroughly as well .... I prefer wiping it with dry graphite, others use various oils or white grease, main thing is get it very clean
Bill | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I agree with Bill on the dry graphite. Lubriplate will harden up in a year or so as will other greases, which will cause the cable to stick once again.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Mar 2012 Posts: 75 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 75 | Ok great does it matter which way I pull it out? 72 year old AC cable I just want to be sure Thanks guys | | |
