8 members (Jay R, Gray_Ghost, WICruiser, Greg_H, Otto Skorzeny, Wheelie, 1955 1 Series, Napco Man),
149
Mod | | | Forums66 Topics128,083 Posts1,056,080 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | Well, the engine blew this morning. Drove it for 100 miles and that's all she wrote. Problem is, I'm an idiot, I should've kept a close eye on the oil, I ran it dry, it burned through a gallon of oil in 2 days. Oh well, the engine needed to be rebuilt anyways.
I'm having a guy take the engine out and rebuild it.
So my question is, what else should I do to the truck while the engine is out. I assume transmission clutch and throw out bearing would be an easy fix, is there anything else I should do while I'm here? | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | If all the other systems worked well up to that point, I'd leave them alone except for checking fluids like rear, trans, and brakes. See any leaks? Fix them.
Drew
| | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | depending upon the yrs/mileage it has, now would be a good time to replace the clutch and clean up the pressure plate. | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Whatever you were planning to do in the empty engine bay, now is the time.
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | well if it burned thru a gal in two days I would have parked it but,
you might considering looking for a complete one for sale vs rebuilding yours, probably a lot cheaper and might have more good stuff in it.. just a thought...
might be time to do some of the other stuff you were asking about in other forums..
Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | If you ran it out of oil and blew it up I'd think twice of rebuilding it. It depends on what failed but I would think if it ran out of oil the crankshaft is junk. | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | What do you mean "it blew"? threw a rod?Hole in the block?If something broke and the engine jabbed,you probably have a bunch of scrap metal.As said already the crank will most likely be cracked,and the rods bent.Even it didn't break anything.The heat will have ruined the rotating assembly. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Be sure to forewarn your engine shop about what happened. Have him check everything carefully including block cracks, etc. Have him magnaflux, acid bath, the works on the block, then make sure he can bore the cylinders no more than 40 thousands over. 60 is really the very limit. Be prepared for bad news.
Then have him check the head. LOTS of these old engines have cracked heads. Hardened valve seats are a good idea at this point. This is gonna cost you, so make sure what you are starting with is worth the expense. If not, there are plenty of other blocks/heads out there to get it right.
I save about $400 by doing all the assembly myself. All I have done at the engine shop is the initial cleaning/testing and machine work. | | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | They are rebuilding it top to bottom and giving me a 3 yr warranty. | | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | So what is the rebuild advice your looking for?
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | They are rebuilding it top to bottom and giving me a 3 yr warranty. How much $$$$$ ????????
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What else to deal with?
Front and rear engine motor mounts?
Make sure the builder does a complete block flush/clean-out, especially at the rear of the block.
Will you get a new oil pump?
| | | | | Joined: Oct 2006 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 126 | Tclederman, great questions. This company is highly reputable in Houston, 80 yrs of operation, including a family member of mine who has used them before. They stand behind their work, they said they would do a complete tear down and rebuild and wouldn't charge labor for other parts that are easy to change out (clutch, throw out bearing, motor mounts, belts, ect). This is why I want a list of parts that I should strongly consider changing at this point.
I didn't think about the oil pump, but I will add that to the list of things to ask about this week. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | sounds like the kind of place that's really doing re-manufacturing, they'll know what needs replacing regardless of its condition [like the oil pump, timing set, and likely water pump and carb], and replace any other things that are "out of spec", it'll be a "turn key" item when they're done
Bill | | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | What would be considered a rebuild? New gaskets, rings and the like or replacing entire valve train and movable parts?
| | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | In the engine bay proper look at your brake and fuel lines. Esp rubber parts. Clean up your grounds and as mentioned new motor mounts might be wise. Take care of any rust and have the radiator boiled.
