0 members (), 68 guests, and 8 robots.
Topics128,021
Posts1,055,355
Members48,420
#96463 07/24/2006 4:49 PM
Junior Member
Junior Member
The '61 ignition switches are different than the 62-66. I tried rewiring a 64 switch (with 5 terminals} to fit my 61 truck (with 3 terminals), but the 64 switch started smoking from the SOL terminal inside the cylinder. :S Any suggestions?
FYI
I cannot replace the key cylinder on my 61 switch because I do not have the original key to pull it out... (I turn my truck on with a screwdriver)
#96464 07/24/2006 6:21 PM
do you have the foot start 235? I think the 3 term switches are from the foot start 235's the 5 terms are for the key start v8 - might find a switch from the earlier trucks - also if you can turn the cyl you should still be able to pull it out, key or not
#96465 07/24/2006 11:28 PM
http://www.colehersee.com/catalog_top/index.htm
Min Qty No
Terminals 3 Screw
Actuators Hencol Lock, 2 keys
Sealed Terminal Insulator No
O-Ring Seal in Stem No
Ground Terminal No
Mounting Stem 5/8 -32
Number of Positions 3
Positions Off - Ign - Ign/Start
Accessory (Current Rating at 12V DC) -
Ignition/Run (Current Rating ar 12V DC) 10A
Start (Current Rating at 12V DC) 5A
Ground (Current Rating at 12V DC) -
Contacts Bronze
Case Material Plated steel
Mounting Panel Thickness 1/8" (3.17)
Hole to Clear Not applicable
Replacement Key Number Not applicable
Details Replaces Delco D-1460, GM 1116508, Motorcraft SW-276
Min Qty No
Terminals 4 Screw
Actuators Coded Tumbler Lock, 2 Keys
Ground Terminal No
Mounting Stem 1" - 24
Number of Positions 4
Positions Acc - Off - Ign/Acc - Ign/Start
Ignition/Run (Current Rating ar 12V DC) -
Start (Current Rating at 12V DC) -
Contacts Copper
Case Material Zinc diecast
Mounting Panel Thickness Not applicable
Jim & Caroline
#96466 07/25/2006 3:50 PM
Junior Member
Junior Member
What does "SOL" on the switch stand for?
#96467 07/25/2006 3:54 PM
Junior Member
Junior Member
I'm not sure what a "foot start" is?
I have a 283, 3 speed automatic in my 61.
#96468 07/25/2006 4:04 PM
Tony,
SOL might mean solenoid, which would be the START position of the switch. You won't have a "foot start". This was the funny pedal on the floor of the older trucks that you would "stomp" to engage the starter.
Stuart
