| | | Forums66 Topics128,266 Posts1,058,386 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 1,426 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,426 | Fellow Stovebolters,
Just weeded through the past 15 years of a floor mat search and couldn't find a consensus on the best for the money. What is the best vendor for the money or are they all popped from China?
Cosmo
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Cosmo,
I have found American Classic Truck parts to be good quality, fit, and price. Jim Carter's are good.
It is anyone's guess as to origin (China is the best bet) and anyone's guess as to most vendors getting them from the same manufacturer/wholesaler.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I've bought several over that past six or seven years from different vendors and they all seem to be sourced from the same place. The problem I have with them is the rubber they use in the reproduction mats will tear very easy, almost like paper. Must be an cheaper quality of rubber because good factory rubber mats are quite tough and even after you cut a notch in it, you can't tear it.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Been hearing a lot about these products. Sound deadening, and thermal products that are sprayed on with a paint gun before putting down your floor mat. Who knows? http://www.lizardskin.com/ | | | | | Joined: Apr 2013 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 144 | used truck bedliner (SEM brand) on my 68 Ranger I sold, I liked it alot. | | |
