4 members (Shaffer's1950, Oswald, JJs55210, 1 invisible), 41 guests, and 2 robots.
Topics128,035
Posts1,055,443
Members48,422
#964616 08/18/2013 1:54 AM
Whats the best way to clean a speedo cable? can I pull the cable out? what do I lube it up with?
Thanks David
yes you can pull the inner out, clean it well with solvent and flush the outer sheath thoroughly as well .... I prefer wiping it with dry graphite, others use various oils or white grease, main thing is get it very clean
I agree with Bill on the dry graphite. Lubriplate will harden up
in a year or so as will other greases, which will cause the
cable to stick once again.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Ok great does it matter which way I pull it out? 72 year old AC cable I just want to be sure
Thanks guys
I've always cleaned my cable and housing, and lubed it with liquid graphite.
http://www.oreillyauto.com/site/c/d...73_1434939_-1&pt=C0073&ppt=C0338
Brian
1955.2 3100 Truck
Moderated by  ndkid275, Phak1
