| | | Forums66 Topics128,165 Posts1,057,010 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | I'm looking for a good respirator for painting/rust work. I've got a fresh air system but would still want a 1/2 mask to use some times. Any recommendations?
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Aug 2012 Posts: 177 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 177 | I went to the local auto paint store and bought a 3M one for paint. Works well as far as I can tell. Lowes/Home Depot carry similar masks for about $10 more. | | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | Normally I would ask what materials you are spraying to insure you are protected (eyes) from isocyanates, but with the fresh air system hopefully you have a full mask with that setup. I do have some of the 3M 1/2 masks in the shop, and also have their full face mask as well. Nice part about that is the filter replacements are interchangeable, so you only need one replacement. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | You guys want to post some "3m" number for what you've used, there are so many different models it's easy to lead someone down the wrong isle.
Denny G
Denny G Sandwich, IL
