| | | Forums66 Topics128,023 Posts1,055,370 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2000 Posts: 90 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 90 | Anyone have a plan for an overhead gantry that could be used for lifting engines, cab/car bodies? Any welding books with a gantry as a project?
I'm just thinking of something basic with a horizontal I-beam for the load and either beams or tube uprights for support. It doesn't have to be adjustable in height; if it was about 10 ft. it would work with my shop's 12 foot ceiling.
I have looked on this site and elsewhere on the web without finding anything. I can find pictures of homebuilt ones and arguments as to what I-beams/structural components to use, but no proven plans.
1959 Chevrolet 3800 Pickup 1937 Chevrolet GC Panel Can you still call it a barn find if it's your barn? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Can you get any ideas form factory built ones? http://www.wallacecranes.com/Those Tri-Adjustable ones are really great, I dream of one every so often... | | | | | Joined: Feb 2007 Posts: 434 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 434 | Don't know if you could buy the steel for what Northern and Horrible Freight want for there pre-made ones. Much less your time. If you haven't looked at them you ought to before setting out on a project. Your results may vary, and if you have already done so, my apologies for taking up this bandwidth.
R-Bo
1959 Apache 1/2 ton Big Window, Short bed Fleetside (under reconstruction) 1966 GMC 305V6 in the family
| | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | How about a jib crane. They take up much less space. | | | | | Joined: Feb 2007 Posts: 434 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 434 | Harbor Freight telescoping one ton gantry on sale for $660.
R-Bo
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Just figure out a way to mount an I-Beam in your shop, then get one of the northern tool, or HF I-beam hoist kits. I haven't done it because I am still trying to A) justify why I need it, since I have an engine hoist and an electric hoist and B) how to get that heavy I-Beam up there without spending a fortune on the support hardware. Good luck! Keep us posted! | | | | | Joined: Feb 2007 Posts: 434 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 434 | You need a I-beam / gantry to pull your cab off the frame. Engine hoist will work, but not as well. Also can set your bed on easily as well. That's how I justified mine after pulling things off my frame using engine hoist and not being happy with it.
R-Bo
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Lots of beds and cabs would still be on trucks if the gantry was a requirement. Stripped these components weigh 300 lbs or less, I have parted 29 of these trucks without a gantry. This is a want not a must. To the original query here is a link for you. http://www.millerwelds.com/interests/projects/we-build/home/project/5690269179 | | |
