2 members (baldeagle, Hotrod Lincoln), 50 guests, and 6 robots.
Topics128,014
Posts1,055,327
Members48,419
#964003 08/15/2013 9:46 PM
I was wondering if there would be any complications in using 53 bed sides on a 54 bed. I know they are different but I don't know why or what exactly is different other than the bed rail being slanted on the 53 and flat on the 54. My truck is a 54 and I have to rebuild the bed and I like the slanted bed rail look of the 47-53.
you might get more response in the bed section forum
to many hot rodders in this forum...
I would think that you could do it though
well for sure one can do about anything
Redryder pix
My Hotrod
The bed depths are different, which makes the front bed panel and tailgate on the earlier bed shorter. If you get those parts along with the bedsides, you should be able to make it fit your '54.
Bill Burmeister
you will need the entire 53 box
