3 members (Bill Hanlon, DES57, Tom McGrath), 118 guests, and 0 robots.
Topics128,117
Posts1,056,296
Members48,439
awk
Offline
I think I may know this, but checking. I believe the location for the 2 holes for mounting the right outside mirror is a mirror image of the location of the left side holes. Is this correct? Adding a right side stock mirror.
awk
Yes, and if you look under the dash, your will see a brace that has holes in it that match the hole locations for the mirror.
Here is a recent post with pictures of the reinforcement plate (brace) that Tim mentions.
NOTE: The bolts are in the WRONG place. A previous owner probably guessed the mounting location for the mirrors and drilled from the outside without checking the reinforcement plate on the other side of the fender. You can see the correct mounting holes on the reinforcement plates.
> Stovebolt post
- Lonnie
- Lonnie
My '54 3104
awk
Offline
Hey thanks guys. This is great info. Good thing I asked before I drilled away. The picture are "fantastic"
awk
awk
Offline
Hey this was very helpful. Got my mirror installed last night with no issues. Thanks again.
awk
