8 members (GRNHydra, David Bush, JW51, Oswald, Otto Skorzeny, Wally / Montana, Guitplayer, NJC), 104 guests, and 1 robot.
Topics128,060
Posts1,055,838
Members48,427
#963574 08/14/2013 12:49 PM
Anyone know what that horrible looking anti-squeak on the top of leading edge of the inner fender is made of? It is used in several areas on the cab. The weirdest place is inside the cab above the hole for the fresh air heater. When I replaced my outer cowl, I found the staples that used to hold the anti-squeak in place. I could not figure out what would squeak in that area as there was no potential for metel-to-metal contact?! The same stuff is also used on the small filler panels near the hood hinge area. Venders are selling rubber pieces for these filler panels but they buckle when you bend them around the corners.
52Carl #963579 08/14/2013 1:25 PM
Punch a series of holes along the curve on the hidden/back edge. The cut some pie shaped slots into the holes and see where that gets ya going around the corners.
A pic of the "stuff" would say a lot.
some 60 or 30 lb roofing felt makes good anti squeak.
Give me ambiguity
or give me something else
52Carl #963626 08/14/2013 3:30 PM
It is C-channel in cross-section and possibly natural rubber based on the high level of deterioration.
52Carl #963688 08/14/2013 8:32 PM
I have read some people paint the contact surfaces with truck bed liner. I figure that helps fight rust, but I do not know if it works as an anti-squeak as well.
Redlegs48 #963706 08/14/2013 9:19 PM
That sounds like a good option. The irregular surface of the bed liner stuff is similar to the blistered appearance of the deteriorated original material. Not that it matters, since you can't see any of the anti-squeak on the inner fenders once everything is installed.
