1 members (JW51),
137
Mod | | | Forums66 Topics128,049 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | Anyone know what that horrible looking anti-squeak on the top of leading edge of the inner fender is made of? It is used in several areas on the cab. The weirdest place is inside the cab above the hole for the fresh air heater. When I replaced my outer cowl, I found the staples that used to hold the anti-squeak in place. I could not figure out what would squeak in that area as there was no potential for metel-to-metal contact?! The same stuff is also used on the small filler panels near the hood hinge area. Venders are selling rubber pieces for these filler panels but they buckle when you bend them around the corners.
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Anyone know what that horrible looking anti-squeak on the top of leading edge of the inner fender is made of? It is used in several areas on the cab. The weirdest place is inside the cab above the hole for the fresh air heater. When I replaced my outer cowl, I found the staples that used to hold the anti-squeak in place. I could not figure out what would squeak in that area as there was no potential for metel-to-metal contact?! The same stuff is also used on the small filler panels near the hood hinge area. Venders are selling rubber pieces for these filler panels but they buckle when you bend them around the corners. Punch a series of holes along the curve on the hidden/back edge. The cut some pie shaped slots into the holes and see where that gets ya going around the corners. A pic of the "stuff" would say a lot. some 60 or 30 lb roofing felt makes good anti squeak.
| | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | It is C-channel in cross-section and possibly natural rubber based on the high level of deterioration.
| | | | | Joined: Aug 2012 Posts: 177 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 177 | I have read some people paint the contact surfaces with truck bed liner. I figure that helps fight rust, but I do not know if it works as an anti-squeak as well. | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | That sounds like a good option. The irregular surface of the bed liner stuff is similar to the blistered appearance of the deteriorated original material. Not that it matters, since you can't see any of the anti-squeak on the inner fenders once everything is installed.
