| | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 23 New Guy | | New Guy Joined: Nov 2001 Posts: 23 | Hi I'm not new to stove bolt but it has been a few years, ben going thru some health issues. I had a bunch of info printed out but can't find it now. I have a 1954 first series with 4 on the floor, if I remember right someone from stove bolt said a pumpkin from a certain year would bolt right in and give me Highway gears. can someone help me out? | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Hey funtime, hope your health issues are behind you. Working on these old trucks just might be the right therapy to keep you going. You may want to pose this question in the driveline forum, I can't answer your question. I know what I did, changed out the rear gears for a 3.55 set-up from Patrick's from Arizona. I can easily cruise at highway speeds, can even hit 80 mph.
Leo | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | He's got a 3600 and they do not make 3:55's for them. Some guys are using a 1967/72 Eaton HO52 pumpkin from a C20 (3/4 ton) or HO 72 from a (1 ton C30) These come in 4:10 gears which should help lower the RPMS and give you a better freeway speed. Do some research on the bolt, lot's of information on doing this. You might want to ask this question in the driveline section. Here's a Great write up from our sister group | | | | | Joined: Nov 2001 Posts: 23 New Guy | | New Guy Joined: Nov 2001 Posts: 23 | thanks for the info. This sounds like what I remember | | |
