4 members (Fannin, 2-Ton, Phak1, TUTS 59), 170 guests, and 3 robots.
Topics128,084
Posts1,056,085
Members48,434
#963237 08/13/2013 10:26 AM
howdy folks..... has anyone come across a tool to squeeze trans oil uphill into the transmission and ball housing ? It's an ugly job to get a funnel and hose and thread it down thru the brake fill hole and pretty impossible to fill the ball housing without taking the floor plate off. thanks for your thoughts / suggestions.
I recently borrowed one of these to fill my transmission: Transfer Pump It worked pretty well but I was concerned with tipping over the gallon jug. Next time I need one I'll buy one of these: Fluid Pump it screws onto the jug so tipping over shouldn't be an issue
When I drain and fill an SM420 4-speed, I remove the shift lever and pour the new oil down from the top.
For maintenance top-ups, after having tried various pumps and tubing, I now top-up the fluid to the fill level (warm transmission) using a 1-quart plastic gear oil bottle that has a fill spout. I use that bottle at a downward angle, needing no tubing. Or, I can attach short tubing to that 1-quart squeezable bottle.
I repurposed a tire sealant jug and pump.
yeah, as Tim points out, the gear oil comes in plastic containers with a spout, works fine for top ups or complete fills, how many times do you plan on doing this? likely has never been drained and filled in it's previous 50 years - if your really fussy about a mess, the Quick Lube places can clean it out for you with a suction machine and refill with a pump, done for your lifetime wink
I have used the plastic bottle to draw up oil from another container. I think they are pretty handy.
1951 1 Ton Completed
I fill just like Tim posted, with a qt. gear oil bottle.
Don't be overly concerned about the U-joint ball
unless it's bone dry from a rebuild, even then it had
to have a little lube when it was reassembled. The
oil will work it's way back thru the rear bearing and
level itself out.
And that's the reason you need to check the gear oil level in
the trans after driving it a couple of times, as the oil works
it way back into the ball your level will drop some in the
trans.
Denny G
Denny G
Sandwich, IL
Go to a marine store ( boats ) and ask for a hand gear oil pump for a 1 liter (1 us quart). They also make pumps for 4 liter ( 1 gallon ) containers.
Keep the 216's running. 1949 1/2 ton model #1314 (US 3104) Brian
Picked up one of these a while ago. Craig's list I think, maybe 20 bucks.
Perfect for transmissions, diffs, hydraulic lifts, ect.
http://s1276.photobucket.com/user/jsdesign2/media/100_0697_zps776bf323.jpg.html
