3 members (klhansen, Danielbolt, 1 invisible), 156 guests, and 1 robot.
Topics128,157
Posts1,056,874
Members48,456
I have unsuccessfully tried to remove the switch cylinder from my 1948 AD. I followed the instructions in the manual: "Insert a wire in the small hole and press firmly while turning the key clockwise", and it still will not come out. Is there a subtle trick to this maneuver? Thanks in advance!
1948 AD Pickup
littlebuddie,
That technique does work. Use a long enough, stiff piece of "wire" - such as, the largest diameter paper clip that will fit the hole.
Spray WD-40 or other penetrating oil into the keyhole and move the tumbler with the key (to distribute the oil). Do this several times.
Tim
there is a spring loaded pin to be pushed. i have found some corroded.
"It ain't a truck if you can't hose out the cab."
Thanks fellows for your suggestions - I will give them a try!
1948 AD Pickup
