7 members (JW51, Uncles51, Jaison, Wayne67vert, Johnny Rib, Robert Crandall, 1 invisible), 70 guests, and 1 robot.
Topics128,041
Posts1,055,481
Members48,424
#96310 07/14/2006 9:33 PM
can anyone tell me the size of the dash hole in a 54 chevy truck. i want to put in a new ign. switch. ron francis has a new type but it has a 3/4 inch hole and i think mine is one inch. it is not here or i would measure it my self. ron francis has an adapter. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#96311 07/14/2006 11:54 PM
curious about your New type,
why not go thru the normal vendors,, are you needing the switch and the keys and cylinder?
I am doing business with thes guys
The filling station they have an on line cat.. you might check and see if they help,, I thougt from 48 to 65 they were the same, as far as the hole..
how much does ron fanscis want for thier new type and how does it differ from the OLD....thanks
Redryder pix
My Hotrod
#96312 07/15/2006 2:05 AM
Ron,
I measured mine...you were correct, it's 1".
Stuart
P.S. No smart arse comments from the peanut gallery!! grin
#96313 07/15/2006 2:31 AM
that small grin
Redryder pix
My Hotrod
#96314 07/15/2006 3:27 AM
Yes Fred, you're the entire gallery! wink
Stuart
#96315 07/15/2006 3:35 AM
sorry, I did not read your bottom sentence,, but you are correct , I am the little nut.. grin
Redryder pix
My Hotrod
#96316 07/15/2006 5:02 AM
Junior Member
Junior Member
Joker, It appears that you are not sure who Ron Francis is, or what he sells. Here is a link for you. Ron Francis
Tom
1953 Chevrolet in progress....slow progress....
#96317 07/15/2006 1:25 PM
JOKER, the cost is 55.95 plus shipping. it is new oem look with the newer keys. a bit pricey but the acc. capability and with the new wiring harness it will work better. the cost is 34.95 for the switch and 20.95 for an adapter for the 1 inch hole. i called them and they don't have a cross referance which seems strange with the multitude of applications they advertise. ron
2017 Buick Encore
See more pix
#96318 07/15/2006 1:25 PM
thanks but I know him,, just was curious why you have to go to him for a key or ignition switch,,thanks for the link though.
Fred
Redryder pix
My Hotrod
#96319 07/16/2006 6:18 PM
i went ahead and ordered the switch from ron francis with the 1 inch adapter. hope it works. ron
2017 Buick Encore
See more pix
