7 members (DoubleB, G508, Peggy M, Bill Hanlon, Otto Skorzeny, TUTS 59, 1 invisible),
200
7
Mod | | | Forums66 Topics128,283 Posts1,058,517 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 18 New Guy | | New Guy Joined: Aug 2013 Posts: 18 | Hi ya'll, I've been fixing up my 59 3g with 9 foot bed. I put in a new clutch last week, now it goes fine only problem is I wanna be able to stop and I can't find rear brake parts. I would love a brake kit that has all the springs and keepers etc. I can get them working if I can find new adjuster for driver side rear. I already have new shoes and wheel cylinders. Are there any other years that are compatible with mine? The rear brakes are 14 by 2 1/2 inches. Thanks for any advice in advance. | | | | | Joined: Aug 2013 Posts: 18 New Guy | | New Guy Joined: Aug 2013 Posts: 18 | Well I've scoured the web and all the parts stores. I think I'm gonna change out the whole rearend. I wanted to keep it stock but its got 5:14 gears, can't find all the brake parts and I've got a real nice set of 16" split rim duallys that won't fit over them 14 inch drums. A newer 1 ton axle with taller gears might get it out on the road more often. | | | | | Joined: Jan 2002 Posts: 237 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 237 | Good move my 1941 1 ton with 9 ft bed was really slow. I added a new 3.73 rear end being pushed by a small block 350 and 700R4 overdrive transmission. I get 70 mph at 2000 rpm. Tires are 7.50 X 17. | | | | | Joined: Aug 2013 Posts: 18 New Guy | | New Guy Joined: Aug 2013 Posts: 18 | I've got a 350 in there already with original sm420 4 speed. Did you swap out the pumpkin or the whole rear end? The junk yard I went to today was not willing to help me find a rear end or a pumpkin to fit it and didn't have line on brake parts. Does any body know what year of 1 ton Chevy rear end would be best to go with? | | | | | Joined: May 2006 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 26 | hey andy, you got a nice truck there I got one just like it, and I found all the brake parts I needed at NAPA wheel cylinders brake shoes 12x2 for front and 14x21/2 for the back they have brake shoe adjusters too and the rubber brake lines for the front and the one for the back. the only thing I couldn't get was a spring kit. almost all the parts also said made in USA, I couldn't believe it. they must have been on the warehouse shelf for awhile, most parts I can find at a good local parts shop or NAPA find a shop that has the old parts books or just ask the guys on here I can't tell you how many times I have asked if anybody has the parts number for a part, I almost always get the parts number or info on who's got it and where to get it. if you change out the rearend save those big brake drums, I don't think they are easy to get. I believe my reareand is the same as yours but I have a 283 with edelbrock intake and 4barrel carb with 350 turbo auto tranny and 17.5 wheels i think top speed is supposed to be 70MPH at about a million RPM that's fast enough for 54 years old with semi power brakes | | | | | Joined: Aug 2013 Posts: 18 New Guy | | New Guy Joined: Aug 2013 Posts: 18 | Hey panmanhd, I found all the brake parts I needed from a fellow stovebolter. I got good brakes now. Put in a 410 pumpkin too. Took her out for a drive. Drives like a caddy! Doors need a lot of work, got new taillights to put on and a couple more small things and she'll be ready. | | |
