2 members (GusG, Otto Skorzeny),
124
Mod | | | Forums66 Topics128,089 Posts1,056,419 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 32 'Bolter | | 'Bolter Joined: Oct 2011 Posts: 32 | Stovebolters -
installed engine after a complete rebuild (runs great!) have now have a dying/dead battery issue. Prior to pulling the engine, no electrical issues. The battery & generator sat in the basement for about 3 months. After re-assembly the engine turned over fast and started right up. Gradually the starter was turning slower and slower as I continued to start and drive while breaking in the new motor. Evenually, the battery was dead. Ammeter was sitting in the middle. While going over my installation procedures, I recall I did not poloriaze the generator. Went back and did so. Charged the battery, and she fired right up. Ammeter almost pegged on the charge side. However, still had the same issue, battery goes dead. Had generator bench tested, no issue, put in new regulator, no change. Did the pull the positive cable off the battery, engine dies. Appreciate any suggestions to track down the issue.
Thanks JWC
| | | | | Joined: Jun 2012 Posts: 85 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 85 | 1. If ammeter shows charging you don't have a generator or regulator problem as long as it comes to neutral after a bit.
2. Engine should not stop when you disconnect the battery, or do you have some kind of electronic ignition?
3. I guessing with key and lights off when you connect and disconnect battery you get a spark? If yes, simple way to troubleshoot is disconnect one thing at a time and see if you still get battery connector spark that was not the prob, reconnect and try something else. You say you only changes the engine, so work around that area. Sure you didn't change any ign wiring?
Like to hear your feedback and provide more ideas. Mike | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | you might just have a dead cell in the battery, that little deal can cause you a big head ache till you find it..not saying but... Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Oct 2011 Posts: 32 'Bolter | | 'Bolter Joined: Oct 2011 Posts: 32 | Mike
Thanks for the suggestions. Will begin the process to locate the issue. Don't have an electronic ignition. And yes get a spark with ignition/lights off. Didn't change any wiring. Just took off the accessory items mounted on the engine. Starter, generator, coil, etc. Will keep you posted. Am sure once discovered it will be something simple & obvious.
Thanks joe | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | may have the coil/starter circuit wired so the coil is hot all the time key on or off, which could cause current flow anytime the engine happens to stop with the points closed
Bill | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | And what kills the engine in a situation like that? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | And what kills the engine in a situation like that?  generator connected in the wrong place? so maybe that's the/another misplaced wire, battery drained by the gen/reg circuit Bill | | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | to find the current draw. install a test light between the unhooked neg battery cable and the neg battery post. Disconnect loads/accessories until the test light goes out. Sometimes more than one load is draining the battery. If test light does not burn replace battery.
1953 Chevy 3100 261 and SM420 53Chevy 31001953 Mack Firetruck 1972 Porsche 911 1986 Honda Goldwing
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | and if you have a drain and can't find it install a cut off switch.. Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Oct 2011 Posts: 32 'Bolter | | 'Bolter Joined: Oct 2011 Posts: 32 | Thanks to all for the diagnostic input. Will tackle the issue this weekend and report back!
Being a D.C. communter has stovebolt disadvantages!
Talked with the local shop that did the initial generator work. They recommended to first run a ground wire from the regulator to the firewall. The regulator I replaced did not have a ground wire. Started truck with some throttle pulled. When I pulled battery cable, truck still ran, until I got to about 1/4 inch from pushing throttle cable all the way in, then truck stops. A re-check of idle speed perhaps and trying to diagnose a power draw as Mike suggested will solve the issue.
Joe | | | | | Joined: Jun 2010 Posts: 301 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 301 | disconnect the positive side of the battery and insert an ammeter in series between it and the battery cable. If you have a sneak current flowing the meter will read it. Then one by one disconnect eletrical devices and look to see if the ammeter shows the current draw stop after you disconnect it. The culprit will show itself. Curious, do you have a stomp starter with the wire terminal off of the side of the starter contacts that you can feed to the coil for direct battery feed while cranking? I've seen those terminals spin while being tightened and internally you might be making contact to the coil at all times right from the battery.
1949 Chevy 3600 1975 W-25 Hurst Olds 1970 GMC 1/2 ton Fleetside 2010 Chevy Silverado
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Stovebolters -
Talked with the local shop that did the initial generator work. They recommended to first run a ground wire from the regulator to the firewall. The regulator I replaced did not have a ground wire. . . Joe The voltage regulator box was not grounded through its case/box/cover. These three mounting screws and insulators assured that it was not grounded. | | | | | Joined: Oct 2011 Posts: 32 'Bolter | | 'Bolter Joined: Oct 2011 Posts: 32 | Stovebolters
With key off, no draw at the battery, thus assume there is no parasitic discharge.
At driving rpm/fast idle, charging rate is 6.8, truck continues to run if battery cable is pulled
At idle, charging rate drops to 6.3, and truck will die if battery cable pulled.
Fan belt is adjusted to 1/2
Generator just weak? Or battery needs charging/driving time?
Thanks Joe | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | probably regulator needs adjusting
Bill | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | just replace it, can't cost you much... Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Oct 2011 Posts: 32 'Bolter | | 'Bolter Joined: Oct 2011 Posts: 32 | I just put in a brand new regulator. Adjustment might be first try, and replacement follow on solution | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | my bad, I read it but forgot it.. maybe it is bad... I got a bad alt once so you never know Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
