| | | Forums66 Topics128,006 Posts1,055,267 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 43 | I am preparing to change out the king pins on my '53. I found a great illustrated guide on this site, but it shows spring clips holding the dust caps in place. My truck don't have these. Do I simply pry these out? Also the caps that came with the set I bought from Jim Carter are concave while the caps on my truck are flat. | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Yep, bang a screwdriver in and pry them out. The new ones go in concave out then you smash them flat to seat and seal the new kingpins.
Bruce | | | | | Joined: Apr 2013 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 43 | Thanks a bunch 55,all this is new to me but I am having fun learning. | | | | | Joined: Aug 2012 Posts: 177 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 177 | I had trouble getting my dust caps out with a screw driver. I ended up drilling a hole in the center so I could pry them out that way. | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Just get a flat blade screwdriver, pound it into the middle then pry out.
Bruce | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The new plugs are installed the same way a similar style frost plug is installed. | | |
