0 members (),
75
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,274 Posts1,058,431 Members48,489 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 64 | I just got my 283 block back from the machine shop.They bored the block 0.30 and turned the crank 0.10 on the main and rod journals.I just checked my main bearing clearance with plastic gauge and this is what I am getting.on the front main cap #1 .004 #2 .0015 #3 .001 #4 .001 #5 .0015 The #1 is what I dont like .This is out of the .003 spec .Would you guys be concerned about this or run it like it is.I check it twice to make sure and I got the same reading. Thank you for your help . Jim
| | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | plastic gage is ok but it really should be check with a dial bore gage, and torqued to 65 lbs. .004 will bleed oil from that main,and starve that rod bearing because of the loss of oil at the main(the rod get feed from the #1main), take it back and have them check it, you may get away with just cutting the cap to tighten up the clearance,baldybenny http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
| | | | | Joined: Nov 2008 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 64 | Okay ,just to see what would happen I switched cap 1 and 4 and torqued and checked them again and I got .002 on both 1 and 4 ? What do make of that? Thanks Jim | | | | | Joined: Mar 2002 Posts: 9,116 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,116 | I would think that you need to measure the journals. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | It's not a good idea to be swapping main caps to different positions.
| | | | | Joined: Jul 2013 Posts: 200 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 200 | As Don said, its not advisable to just randomly swap main caps unless you have a dial bore gage to confirm they actually fit that main saddle. You should take it back to the machine shop so they can verify that the caps are not in the wrong position and number them for you. Unless you numbered the connecting rods and caps, they should check them and number them for you as well. Plastigage is only good for checking the clearance at the exact spot you place it on the crank journal, it cant tell you what is happening at other places around the housing bore.
We cannot solve our problems today using the same thinking we used when we created them! Albert Einstein
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | Yes, don't be swapping main caps around. Unless of course you got them mixed up in the first place. You need to check for dimension, and out of round of the bearing bores in the block with the caps installed and torqued to the proper spec. check the crank journals. Install the bearings in the bores without the crank and once again, torqued to the proper spec. Set up the dial bore gauge with a micrometer. You should see some eccentricity with the area 90 degrees from the separation line of the bearing cap being the number you want to see, while if you turn the gage right or left it should get incrementally larger somewhere in the range of .002" (I can't remember for sure, but just look it up). If it comes down to it you could just turn the one journal down to the next size smaller and get a single bearing. (remember in the inlines, EVERY journal is different size) If you cut the cap, without line boring, you would essentially be making the hole oval, assuming of course it was round to begin with, not to mention off center. To summarize, there are a few issues that could be at play here. the bore is too big, the bearing is out of spec, or the crank got turned too small. Each situation requires something diferent, if the bore is too big, you will need to have the cap(s) cut and line bored, the bearing would need to be replaced ( I would assume at someone else's expense), and if they ground the crank to the wrong size, I would assume they would be responsible for that as well, I do know if it was mine, they would find me another crankshaft and make it the way I was paying them to make it. I got very cynical during the rebuild of my last engine, I made so many trips to the machine shop, I had to take the head in 4 times before it got right. The cam grinders lost my brand new cam, that had never been in an engine, never did find it. If I had the money, I would buy all the equipment and do it myself. | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | The 283 I just put together had the number cast onto the cap. Wasn't any question about which cap went where and didn't have to number them. Also make sure you install the cap with the cast arrow pointing toward the front of the engine.
If the block is out of spec then it will need to be line bored to correct it. | | | | | Joined: Feb 2011 Posts: 1,363 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,363 | I just got my 283 block back from the machine shop.They bored the block 0.30 and turned the crank 0.10 on the main and rod journals.I just checked my main bearing clearance with plastic gauge and this is what I am getting.on the front main cap #1 .004 #2 .0015 #3 .001 #4 .001 #5 .0015 The #1 is what I dont like .This is out of the .003 spec .Would you guys be concerned about this or run it like it is.I check it twice to make sure and I got the same reading. Thank you for your help . Jim And they bored it way out of tolerance at .3, I think you mean .03 ?? It is either likely they goofed up on the grinding of the journal or the bearing shell is not correct. You need to find someone that can measure everything. The plasigage is fine to find a problem but its not going to tell whats causing the problem.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Did they line bore the block, or just bore the cylinders and turn the crank? | | |
