5 members (baldeagle, MNSmith, 46 Texaco, Shade Baby, 1 invisible), 94 guests, and 6 robots.
Topics128,018
Posts1,055,342
Members48,419
#962367 08/09/2013 10:11 PM
Hi! I need some help with my 1951, 3600, steering column. I took is out and sanded it and cleaned it up as part of installing power steering. I cut off the column above the steering box knowing I would have to cut it to the correct length when I put it all back together. I have now finished the power steering box and pump installation and am putting the steering column back in. I am not sure how far the steering column is suppose to stick out from the dash and I have no way to determine it. Could someone measure the distance from the dash to the bottom of the steering wheel for me so I know how far to extend the tube into the cab? I would really appreciate it. Thanks!
Rick In VA #962373 08/09/2013 10:21 PM
Depends entirely on how big your belly is. If it already has some size to it, allow for some further expansion. Seriously, you only need to worry about column shifter clearance from the dash.
Sir Searchalot
Sir Searchalot
Sit in it if you can, or simulate sitting in it. Push seat back, hold wheel until comfortable, measure. you can also change the angle a little if you wish.
Thanks for your comments but it is not what I asked for. The seat is not in the car and I need the measurement.
Sir Searchalot
Sir Searchalot
From the face of the Column mounting bracket to the top of the horn button hole is 14 3/16. To the top of the horn button: 15 1/8. 1959 Panel, all stock.
Rick In VA #962579 08/10/2013 10:09 PM
Many thanks bartamos! That should do the trick.
Rick In VA #962585 08/10/2013 11:00 PM
Sir Searchalot
Sir Searchalot
You betcha.
Moderated by  ndkid275, Phak1
