2 members (Peggy M, UtahYork), 127 guests, and 3 robots.
Topics128,042
Posts1,055,515
Members48,424
#96226 07/06/2006 6:40 PM
I need to replace the coil resistor for my 1949 chevy 1/2 ton. It is a 12 volt system. Where do I go to buy one, and what do I ask for?
Thanks for the help.
#96227 07/06/2006 6:57 PM
duck457,
It's possible to purchase a new coil with internal resistor and do away with the firewall mounted dinosaur. Any parts store should be able to fix you up with a 12v coil/no external resistor required. A slight wiring change is needed, but it's simple.
Stuart
#96228 07/06/2006 7:02 PM
any parts store,,you have to get to about 9 volts or points won,t last...doc
#96229 07/06/2006 7:34 PM
borg/warner (nascar)
ru4....coil resistor.
Redryder pix
My Hotrod
#96230 07/06/2006 8:32 PM
Riding in the Passing Lane
Any parts store or specialtie store has them available. Ask for an ign. resistor for a 55 up chev.
1972 Chevy c10 Cheyenne Super
#96231 07/06/2006 10:14 PM
If you've converted the charging system adn guages to 12 v, when you change the coil if you change the points and condensor to 12 you can get a 12v coil, and eliminate the resistor, if you want.
#96232 07/07/2006 2:18 AM
What do I ask for to get a 12 volt coil with internal resistor? Specs for 49' are 6 volt.
Will other years with 12 volt specs work?
Thanks to all.
#96233 07/07/2006 2:34 AM
ask for just that - a 12V coil w/ internal resistance - same for anything, but you can fool them clueless counter guys by telling them it's for a late 235 grin
#96234 07/07/2006 3:13 AM
why buy a coil just to take care of the resistance deal.. he already has a coil it appears, and he is asking for the resistor,,,,,it is a lot cheaper.but.....
Redryder pix
My Hotrod
#96235 07/07/2006 4:48 PM
duck457,
The Standard Ignition coil number is #UC15. If you have a Carquest in your neighborhood, they can cross that number to a Carquest equivalent which sells for $16.00.
If you opt for a coil with the internal resistor, you can get rid of the externally mounted ceramic resistor, which can be problematic. On the downside, the rig will not get the benefit of a little hotter spark when starting (cranking). If you are lax in the tune-up department, this could make a difference.
As joker pointed out, you already have a coil...it might be easier to just stick a new ballast resistor on the truck and call it good. It is nice to know that there are options though!
Stuart
#96236 07/07/2006 7:08 PM
Go to your local parts house and get a 1969 ballast resistor. Chrysler part # 227559 cost .89 list $3.00 no longer available throught chrysler. I think napa has them. They make 2 styles 2 post and 4 post. You need 2 post but can use 1 side of the 4 post. The 4 post # 3874767 list for 10.25
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
#96237 07/07/2006 7:15 PM
i always carried a spair in the glove box. saved me once and saved a stranger once.
"It ain't a truck if you can't hose out the cab."
#96238 07/09/2006 5:38 PM
Got the Chrysler resistor. Life is good.
Thanks to all.
#96239 07/09/2006 6:28 PM
duck457,
Lee Iacocca would be proud of you. grin
Stuart
#96240 07/09/2006 6:48 PM
mine was much cheaper then that but glad you got what you wanted..
Fred
Redryder pix
My Hotrod
#96241 07/09/2006 10:33 PM
No applause please, Just throw money.
