2 members (1955 1 Series, KEVINSKI), 101 guests, and 4 robots.
Topics128,185
Posts1,057,207
Members48,465
This is a picture of my grandfather at the farmers market. I remember riding in this truck with him. I found a 1969 truck for sale that looks just like this. With very little information in this picture can anyone tell if this truck is a 1969 model? Thanks
http://i1251.photobucket.com/albums/hh545/dalewis29/20130808_143442.jpg
Going from the small rear window, I would say it's a '67. '67 was is the last year for the small window cab.
Bill Burmeister
The C20 I found for sale is advertised as a 1969 year model and has the same window. The link below is the one I found for sale. Do they have the wrong year model on it?
http://i1251.photobucket.com/albums/hh545/dalewis29/greentruck-mar0163.jpg
Can you get a pic of it from the front? From what I can see in the pic you've posted of the one that's for sale, it looks to have a '68 doghouse on it. Would need to see it from the front to tell for sure.
Bill Burmeister
67 was the last year for the small window as standard [with a big window option], 68-72 the big window was standard, the small window cab was the option .... what will tell if Grandads truck was a 67 is if it had NO side markers, otherwise you need to see the grille to tell for sure what year it was
Here is a picture of the front of the one for sale.
http://i1251.photobucket.com/albums/hh545/dalewis29/1969-3.jpg
Also, do the hub caps on the picture with my grandfather in it tell us anything about the year?
What are side markers? thanks
That's a 69 or 70 grille.
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=9
Check the VIN
Side markers are lights: little amber lights on the side of the fenders started on all US vehicles in 68.
red58, I thought 67 was the last small back window, period.
Interesting...
lookingfor3600, That's a nice looking truck. Buy It. smile
Professional Novice
I thought the same thing about the small window cab. None of the sources, even GM Heritage mention the option after '67.
Now that I've seen the front, definitely '69 or '70, I'm leaning more toward '70, as the grille has the extra finned inserts that the '60 doesn't have.
Bill Burmeister
well, maybe not a listed option, but I have seen 68's with the small window, might be 'remainder' cabs that got used in early 68? or maybe ordered by a dealer that way .... agree the one in question looks more 70 than 69, but the VIN is what'll tell
The hubcaps look like '67 or '68.
The only way to be sure of the year is to look at the VIN number. The 5th digit denotes the year.
Being nearly 50 years old it may have had a different bed and doghouse put on it....
Print this out and take it with you when you look at the truck. Hope this helps and good luck to ya thumbs_up
1967-1972 VIN Number Codes
Example: CE149J 100001
Chassis Designation (1st digit)
C= 4x2
K= 4x4
Engine Deisgnation (2nd digit)
E = V-8 Gas
S = Six Cylinder Gas
GVW Range (3rd Digit)
1 = 1/2 Ton
2 = 3/4 Ton
3 = 1 Ton
Model Code (4th Digit)
4 = Pickup with Cab and Bed
Model Year (5th Digit)
7 = 1967
8 = 1968
9 = 1969
0 = 1970
1 = 1971
2 = 1972
Assembly Plant
A = Atlanta
B = Baltimore
F = Flint
J = Janesville
N = Norwood
P = Pontiac
S = St. Louis
T = Tarrytown
Z = Fremont
1 = Oshawa
Vehicle Serial Number
100001 = 1st Unit Built
1967-1972 Model Number Codes
(The Model Number is located on the inside of the glove box door.)
Example: C E 1 09 9 34 J 100001
C = 4x2
K = 4x4
P = Forward Control
E = V-8 Gas
1 = 1/2 Ton
2 = 3/4 Ton
3 = 1 Ton
Cab To Axle Dimension (4th Digit)
07 = 42"-47"
09 = 54"-59"
10 = 60"-65"
12 = 72"-77"
13 = 78"-83"
14 = 84"-89"
15 = 90"-95"
7 - 1967
8 - 1968
9 - 1969
0 - 1970
1 - 1971
2 - 1972
Body and Brake (6th Digit)
02 = Flat Face Cowl
03 = Cab
04 = Stepside Pickup
05 = Panel
06 = Suburban
09 = Cab, Platform, and Stake Rack
12 = Windshield Cowl
16 = Suburban (Tail and Liftgate)
26 = Custom Suburban (Panel Rear Doors)
34 = Fleetside Pickup
35 = Foward Control (Square Front)
36 = Deluxe Suburban (Panel Rear Doors)
42 = Forward Control Chassis
45 = Forward Control Panel (Round Front)
Assembly Plant
A = Atlanta
B = Baltimore
F = Flint
J = Janesville
N = Norwood
P = Pontiac (GM Truck)
S = St. Louis
T = Tarrytown
Z = Fremont
1 = Oshawa, Ont., Can.
Do the hub caps with my grandfather in the picture help?
Here is the next big question.......I have checked into having a vehicle shipped. There are so many options out there. Any suggestions for the most reasonable option? It does not need to be an enclosed trailer. Shipping would be from Iowa to Georgia. Thanks
your best bet is to just shop around, put a post in the Hauling Board here, and check at Yesterdays Tractors hauling section, both have dependable carriers, ask for quotes
The caps on your grandfathers truck look to be either '67 or 68.
Bill Burmeister
