4 members (SmalltownTRKGuy, Otto Skorzeny, TrknGMC, TooMany2count), 106 guests, and 8 robots.
Topics128,077
Posts1,056,032
Members48,433
#960551 08/01/2013 7:06 PM
My friends, I've got a 66 long bed 250 six with a four speed "granny" trans... Two years ago I rebuilt the engine and it runs great... thanks to this site and advice from some great local mechanics. A few months ago it started to make a howling sound when ever I let off on the gas. Give it some gas and the sound immediately stops. Going down hill if not accelerating, it starts to howl again, going up hill with power, no noise. Is this a trans problem or drive train problem...? frankly the noise sounds right under the seat... any help with what it might be would be greatly appreciated.
sounds like probably the pinion bearing, especially if it happens in a certain speed range
Sandcaster #960886 08/03/2013 11:32 AM
Thanks.... is this an easy repair?
Sandcaster #960888 08/03/2013 11:38 AM
depends on your skill level, replacing the pinion bearing and seal should be outlined in your shop manual, and the parts should be readily available at a FLAPS
Riding in the Passing Lane
Check to see if the pinion nut has come loose.
1972 Chevy c10 Cheyenne Super
Sir Searchalot
Sir Searchalot
Throw out bearing possibly or Ujoints. The pinion nut should be like 250 Ft Lb torque, Could be what was said: Nut or pinion brg. Try down hill in neutral, coasting, that way ring/pinion and ujoints are being driven by the forward motion, not the engine. See what happens. It's something where the torque of the drivetrain is taking out the "slop" and when relaxed is howling. Ujoints are easy and cheap to replace to see if there is any improvement. Usually you can not tell if ujoints are bad by exam or feel while on truck. You are half way there when you check/tighten Nut grin
Thanks for the tip
