Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Phak1, Hotrod Lincoln, DoubleB), 154 guests, and 4 robots.
Topics128,284
Posts1,058,526
Members48,490
#96213 07/03/2006 3:29 AM
I currently have a 12 volt system using a volt meter, but am switching back to an ammeter to be more original. I already have been advised of the pros and cons, but I have one question. What side of the ammeter does the main/fatty altenator wire attached to? The battery side or the load side?
Thanks to all.
#96214 07/03/2006 4:51 PM
load side
"It ain't a truck if you can't hose out the cab."
#96215 07/03/2006 7:03 PM
Here's on more question. My ammeter is not labeled. Looking at the ammeter from the back, which post does the battery attach to?
Thanks to all.
#96216 07/04/2006 3:32 PM
The load side is for the electrical 'load', such as lights, etc. The other side' battery' is attached to where the power comes from, battery /alternator. You can test for proper operation by connecting the ammeter and turn on the lights without the engine running, if the needle swings to the (-) side it is connected right. If it swings to the (+) side it is connected backward, so just reverse the wires.
illegitimi non carborundum
#96217 07/04/2006 4:17 PM
No 52 Ted, one side is load/alternator (generator), the other side is battery.
Simplicity leads to reliability.
