1 members (carbking),
144
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 123 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 123 | 1953 Chevy 3100 with 1959 235 engine. Anyway broke down last night, no fuel. Got a new pump today from Jim Carter and installed it. Back on the road. Rocker arm pivot pin on old pump had worked its way out one side, putting it in a bind or something. Lucky to live in Kansas City: Jim Carter, Classic Parts, and LMC all close by. Towed it home with a Toyota though. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | NAPA or any other flaps can supply a fuel pump for your 235 | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Don , I read he already got a new one at JC and explains about what was wrong with old one. There is no question here.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I think the point Don was making Bart, was that if someone is on the road broke down with a fuel pump failure, you could also readily acquire one at a NAPA store or your FLAPS.
Denny G
Denny G Sandwich, IL
| | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | I had an oil leak on my 216 and traced it to the pivot pin on the fuel pump. It had slid partly out and allowed oil to drip out the hole on the other side. Besides tools, a fuel pump is one of the spare parts I keep in the truck.
1939 Chevrolet Stake Truck
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I have had several fuel pumps do that. I now have one where the pivot is not exposed. | | |
