| | | Forums66 Topics128,152 Posts1,056,825 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#96201 07/02/2006 1:30 PM | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Hi folks,
I got a heater bloer assembly and would like to test the motor to see if it works. It's a 60-66 GMC/Chevy unit. Can someone give me an Idear as how to connect power to this unit? Also could I use a a 12 volt charger to be the power source?
Jake | | |
#96202 07/02/2006 2:27 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I'm not familiar with your blower but the way I would test it would be to touch the hot wire to the positive post of a 12v battery & ground the case to the negative post. If it's grounded by a wire simply ground the wire instead of the case. Be sure to have a good hold on the motor. Those things can have some torque. I would use a battery instead of a charger.
#96203 07/02/2006 11:43 PM | Joined: Apr 2006 Posts: 14 New Guy | | New Guy Joined: Apr 2006 Posts: 14 | A typical 10 amp battery charger will work fine to power the motor.
Larry | | |
