6 members (55shaker, Lightholder's Dad, TooMany2count, klhansen, Phak1, 3800GUY), 76 guests, and 1 robot.
Topics128,138
Posts1,056,440
Members48,441
#961685 08/06/2013 11:43 PM
I just got done rewiring my 54' Chevy truck. I was wondering what the ammeter should be reading while running. Right now my just seams to stay right in the middle of the gauge. Where can I put a test meter at to see if its a gauge, generator or voltage regulator problem? Thanks guys
not a problem, you want the ammeter to indicate a 'neutral' condition, the battery is charged and the generator is keeping up with demand, what the ammeter is telling you is the amount of current being sent to [drawn by] the battery ... what should happen is the ammeter drops minus while you're cranking the engine, once started, it should move back to neutral, fast or slow depending on how long it cranked - might take a jump up to plus at first and fall back to neutral, all good
Ok thanks. Even with the engine shut off it still is in the middle. When I crank the motor the needle hardly does anything. I will keep an eye on it to see if it changes at all. I guess I will know when I get the lights hooked up.
Pull your headlight switch on and you should see the needle drop
about to the middle of the negative side. The starter won't
show a big drop but when the engine fires up you should see a
pretty sharp rise toward the positive side for a few minutes.
It's possible that you have some poor connections due to
corrosion also so I'd check them before considering a new
gauge.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
centered is the "rest position" with the key off, turn the lights on with ignition off and it should show a strong discharge ... how much the ammeter moves in any particular truck is variable, the needle being roughly centered under normal conditions is what counts ... keep in mind that these gauges are not scientific instruments, the ammeter is primarily to warn of sudden deviations from normal functioning, so you need to learn how your particular gauge reads under all conditions
