2 members (Shaffer's1950, 1 invisible), 117 guests, and 2 robots.
Topics128,094
Posts1,056,464
Members48,443
#961324 08/05/2013 1:31 PM
JAW
Offline
I have a 54' Chevy 3100 that I have decided to begin restoration on. The drive line is all original, transmission is a 4 on the floor, torque tube and original rear end. I believe the engine has been rebuilt, 235 ci. I would like this truck to be able to be a daily driver, or one that I can run up and down the highway with at highway speeds but want to keep the truck as original as possible. Any suggestions as to gear ratio changes or if it would be best to get rid of the original rear end and torque tube? Any advice would be greatly appreciated.
welcome, you might considering going to the welcome forum and giving an intro...........a lot of tips on your topic,
you might try a search in the forum, that works really well
or just scan thru some of the posts in the general truck forum and such.............welcome to the best truck site in the world..
read this for some tips
Redryder pix
My Hotrod
Search for posts describing the 3.55 ring and pinion gears conversion, which allows you to keep the original enclosed drive shaft.
I made this change in my 1954 Suburban, along with changing to LT215/85R16" radial tires. This resulted in about a 20% decease in RPM, allowing easy/quiet cruising at 60-65mph. MPG did not decrease at those speeds.
Make sure your brake system is good, and make sure all your front-end and suspension parts are good.
JAW
Offline
Thank you for your reply's. I appreciate the help. Searching through the forum I found PatricksAntiqueCars. I guess I'll start there.
Thanks again
Patricks is a good place plus a nice guy..usually he is willing to help answer questions on the phone...
the 52 I sold had a bunch of Patrick stuff on it... no problem
Redryder pix
My Hotrod
