1 members (69Cuda),
83
Mod | | | Forums66 Topics128,096 Posts1,056,487 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | So I've read the tech tip about king pins, but it was written about a 1/2 ton. How bad of a job is this going to be? I'm working on a 41 1.5 ton. Suggestions, or things that work and don't work?? Thanks! | | | | | Joined: Jan 2000 Posts: 101 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 101 | I have a 45 1.5t and probably am in the same boat. Steering is all over the place.
1946 1/2 ton - 1962 "261" 1953 1/2 ton 5-window - "235" 1955 1/2 ton - 55 "265" Corvette motor 1959 1/2 ton Fleetside - "283"
| | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | having the right tools make a world of a difference. | | | | | Joined: Mar 2013 Posts: 235 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 235 | I had a shop replace my king pins since I don't have the right tools. I got the parts from Chevs of the 40s. The mechanic said the parts fit perfectly and he was surprised how easy the replacement went. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Hard part can be getting the king pins pressed out of the axle, sometimes they're really rusted in tight. Other times they tap out with a rubber mallet...
After that you remove and replace the bushings and have them reamed or honed. Trick there is ensuring they're reamed on the same center line as each other, easily done with a reamer with a floating pilot, or simpler yet by taking them to an automotive machine shop. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I have only done king pins on 47-55 1/2 ton trucks (which do require reaming of the bushings). When I could not remove the king-pin, even using a small hydraulic press, I have taken the axle assembly (with spindles/knuckles attached) to a front-end shop.
If you do not have the reamer tool (for the bushings), you might want to find a front-end shop that has someone who will work on your assembly. If a king pin is loose in the axle, you will need over-sized pins and the holes in the axle will also have to be reamed.
A few years ago, I needed an axle reamed for an over-sized pin and was quoted $400 (lowest quote) just for the reaming. I bought an adjustable reamer (about $30) on eBay and did it myself (1/2 ton truck).
As posted above, from ashton onwards, you need the right tools (and experience does help). Check around for a quote from a shop - tell them you will bring them a cleaned assembly - the axle with knuckles in place.
You might also want to check around to see if you can find king pin sets for your truck - standard size, 0.10" oversize pin/bushings, and even 0.020" over-sized pins and bushings. Don't buy them, just find a source This would assist the shop in the time needed to find old parts.
What is the diameter and length of the standard king-pin for your year/size truck?
| | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | Thanks everyone. I'm not sure of the size.. I have the kit somewhere, but don't remember the size. I am going to have them done, as per advice. I found a shop locally that will do them with no problem. They want to see it for a quote, so I'll get'er running and down there. Easier than taking the axel off (again) and running it down. | | |
